Using multiselect fields in Airtable in-built automation
Topic Labels: Integrations
1081 0
Afonso_Firmo
Hi Team,
I am using Airtable automation to create a record on a different Table after a Form is submitted. Everything works fine except when I try to use the automation on a multi-select field.
In the Action section I’ve chosen a field that is a multi selected. It seems that it only allows me to do a new list instead of taking the values across.
When I test the automation I get the following error.
Can someone help?
Thanks.
0 Replies 0
