Using Repeating Fields to Add Multiple Project Leads in a Form?
Topic Labels: Data Workflow Design
205 1
iamericfletcher
I'm looking to create a form with fields for a project lead like name, title, affiliation, and email. What's the best way to allow for multiple project leads? Ideally, a user could click a checkbox to 'Add Additional Project Lead'. There's no limit on the number of leads. Any advice on using repeating fields for this? Basically, trying to determine if I can somehow not have to replicate each field an ungodly amount of times with a checkbox between each conditionally showing the next bunch of project lead fields conditionally based on the particular checkbox (nightmare).
No, this is not possible with Airtable's forms. You can do this with Cognito Forms or JotForm, and then you would bring your form submissions into Airtable using Make.
