Jul 26, 2019 06:37 AM
I am trying to build an order system with several tabs:
Orders at vendor (I buy from 1 vendor)
Orders from customers
Customers
Products
An order from a customer has several products and might have more than 1 from each item. And that is where I get stuck. How can I add more than 1 of an item when there are multiple items?
If it was just 1 item more times the colums would be product & amount, but that wont work.
I feel like I am missing something obvious…
Solved! Go to Solution.
Jul 30, 2019 09:25 AM
You have Products
- a record for each Product
A Line Item
will be linked to a single Product
, will declare an “Amount” of that Product
to be ordered, will produce a “Total” for itself by multiplying Product > Price
(obtained via Lookup) by “Amount”, and finally, will be linked to a single Order
An Order
will produce a “Total” for itself by SUM’ing Line Items > Totals
(via Rollup) and applying any tax modifiers, discount modifiers, etc. that are needed.
A Product
will end up belonging to many Line Items
A Line Item
will always only reference one Product
and one Order
An Order
will usually include many Line Items
A Product
is never linked directly to an Order
, it is linked only through Line Items
Jul 26, 2019 10:51 AM
You’re not missing anything obvious. This is a genuinely difficult problem to solve in Airtable. With your own orders from the vendor, you can easily solve this by having a Line Items
table sitting between your Products
and Orders at Vendor
tables – but you can do this because you have direct access to your tables, so it’s easy enough to manage creating Line Items
that can define quantities.
A customer, however, only has access to forms from your Airtable, and forms can only present data from a single table to the customer, and the customer can only submit a single row (record) of data at a time – so it’s not possible to have a customer create multiple Line Items
as part of an Order
through a single Airtable form.
I’ve not played with external form services like jotform.com – perhaps one of these could be configured to do what you need :man_shrugging:
Otherwise, the best I’ve been able to come up with is to have another table of Product Packages
where Products can be linked to and then put into multiple “packages” of quantities.
So let’s say you are selling paper clips, so you have a single record in your Products
table for a Paper Clip
as a product. Now you’d create a record in your Product Packages
table, with a link to the Paper Clip
product, and then a Quantity
of 1. In the name (primary) field of the Product Packages
table, you’ll concatenate the
{Product} & " x" & Quantity
so it will read “Paper Clip x1”.
Now you can create as many Product Packages
as you need for commonly purchased amounts of the Prodouct
Paper Clips
, and your Customer order form is linked to the Product Packages
table instead of the Products
table.
It’s not terribly elegant, but if a customer starts typing “Paper Cl…” into the Products
field of your form (which is presumably a linked record field to your Product Packages
table), they will be presented with a filtered list of Product Packages
showing all of the packages available for Paper Clips
Perhaps that’s an approach you could take…
Jul 27, 2019 01:37 AM
Hey Jeremy,
Thank you for your extensive answer! That really helped. I don’t need my customers to be able to get into airtable directly. That would have been nice but I can fill it in for them. So the most important part is the Line items table. Could you explain or show an example of that?
Jul 28, 2019 09:56 PM
Check template Product Catalog - It has Order Line Items.
It will give you idea.
Neal
Jul 28, 2019 11:10 PM
Thank you! I looked at that one before but it didnt make sense then. I understand it now!
You have Products
A Line Item
An Order
A Product
A Line Item
and one Order
An Order
A Product
Jul 12, 2020 02:45 PM
Whats the best way for a client to complete an order form if I use the Product Catalog Template? I would like for a client to be able to order their own items with quantities.
Sep 13, 2020 10:00 AM
That’s why we built a solution for this problem. Our form allows your clients to add their own line items inside the from while still linking them to the order
May 09, 2022 01:57 AM
Hi Jeremy,
Tried to wrap my head around your answered solution and replicate it, but with no success. I think it’s beyond my Airtable knowledge and complexity skillset.
Have you created a base with that particular solution you provided, that you could share?
Thanks in advance, looking forward to your reply :grinning_face_with_smiling_eyes:
Sep 29, 2023 09:10 AM
I would love to see it as well. I absolutely get how it works, perhaps much thanks to this random video here https://www.youtube.com/watch?v=88YShTRwQ94, but I don't get how to populate the List Item table, say from Etsy or Shopify orders. Do Make/Zapier have a ready-made solution that breaks the order list into individual list items?
Thanks a lot for the help.
