Airtable - Automations Problem
Topic Labels: Automations
674 1
Daniel_Ferreira
Hi there, i have a problem with my automation in airtable. I’m trying to send this email to two diferents fields but something is wrong.
Hey @Daniel_Ferreira_Orne!
You’ll want to be sure to insert a comma between the two emails.
This will allow Airtable to register that there are two different values that need to be evaluated.
You’ll just click into the field and type it in and it should work as expected!
