Airtable Base on Qlik Sense
Topic Labels: Integrations
1804 1
Adriano_Gomes_C
Hi, I´m a basic user of Airtable and I´d like to use Airtable bases as data on Qlik Sense. Does anyone can help me on this?
Thanks in advance!
@Adriano_Gomes_Coelho,
I’ve integrated external data with Qliksense one other time and it worked well - Coda.io to Qliksense. Since there are no Zapier recipes for doing this (that I know of) you’ll have to use the API’s from each platform to read from Airtable and write to Qlik.
I’m pretty sure Integromat doesn’t support Qlik either (natively), but it might be able to get you there with an out-of-the-box JSON interface.
