Save the date! Join us on October 16 for our Product Ops launch event. Register here.
Apr 27, 2020 06:33 AM
Hello everyone!
This being my first posted question, please let me know if I haven’t provided enough information / context, or if this question is being asked in the wrong Category. This will help improve the way I phrase the question as well as where to address it.
I am looking into Zapier, using it to automatically create a record, and when creating this record automatically filling in some of the data. Most of it is pretty straightforward, but I can’t figure out yet how to instruct Zapier to automatically check some of the checkboxes in the row / record.
If anyone either knows the answer, or knows where I can find the answer, that would be great!
If this question has been asked previously, I checked for an answer but I could have missed it, I will remove this question so that things will stay organised.
Thanks in advance,
Gunnar
Solved! Go to Solution.
Apr 27, 2020 06:41 AM - edited Apr 21, 2024 08:34 AM
If you have a checkbox field, you can send the word “checked” to that field in order to check the checkbox.
BTW, one important thing to note is that I highly recommend switching away from Zapier and using Make's automations & integrations instead.
The reason for this recommendation is because Make is INFINITELY more powerful & customizable than Zapier, yet it is SIGNIFICANTLY CHEAPER than Zapier.
I wrote an entire post here comparing Make vs. Zapier.
If you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread. For example, here is how you would instantly trigger a Make automation from Airtable.
I also give live demonstrations of how to use Make in many of my Airtable podcast appearances here.
For example, in this video, I show how to work with Airtable arrays in Make.
Apr 27, 2020 07:04 AM
This works! Thanks for your quick reply :slightly_smiling_face:
