Conditional Color Coding of Columns/Fields
1004 3
Caitlin_Leith
Hi - is it possible to color multiple columns using the conditional logic? For instance, we have 8 columns:
  1. Budget 1
  2. Spend 1
  3. Difference 1
  4. Budget 2
  5. Spend 2
  6. Difference 2
When setting up the conditional logic, we’d love to be able to say “if the difference is less than x, make the field green.”
If isn’t possible, are there any workarounds that you would suggest? Thank you!
3 Replies 3
You can only apply conditional color logic to the entire row, not individual fields (columns). But this is a great feature request that I would personally love to see in the product! Please submit it to the Product Suggestions forum.
Thank you! I will do that now.
Agreed! Me too! This would be epic!
