Create Record automation error
Topic Labels: Automations
974 1
Philip_Aroneanu
Hi all -
I set up an automation to add data from one sheet (Phil/Jennie check-in) into another (Tasks) automatically. When I test the automation out, it works, and the data is copied over, but when I let it run on its own, it delivers blank records. Has anybody run into a problem like this?
Screen Shot 2021-02-17 at 8.55.51 PM
Screen Shot 2021-02-17 at 8.56.05 PM
When a record is created, unless it was created by a form, all the non-calculated fields will be empty.
Use a different trigger, such as “when record enters view” and filter the view to only show records which have the necessary fields filled in.
