Creating a custom block to connect data to Sanity.io
Topic Labels: Extensions
1646 3
Holly_Gronau
When using Sanity it’s really important all of our entires in our base have unique id’s not just on tables but in the base itself. Are the id’s for the entry unique to the table or the base?
18 - Pluto
18 - Pluto
While this post by an Airtable employee states that record IDs were globally unique two years ago, there is no guarantee that they will remain so.
I recommend using a combination of the base ID, table ID, and record ID to uniquely identify a record.
3 Replies 3
18 - Pluto
18 - Pluto
Thanks! I appreciate your time answering this it’s very helpful so I don’t end up with a duplicate record along the way.
John_Williams
Hi there
Looks like our expert team help you out here
Contact us at: support@saaszone.co
Visit : saaszone.co
