I’m trying to create a formula that looks for either of 2 fields to be checked. Can someone tell me what I’m doing wrong? I can get it to work with either/or but trying to look up both, I’m stumped. Thank you!
Hello! Breaking it down, you would format it as follows to consider two criteria:
Edited
AND statement AND((Agreement =1), ({Umbrella Agreement}=1))
or
OR((Agreement =1),(IF{Umbrella Agreement}=1))
Then, adding in the IF you would write this like : IF(OR((Agreement =1), (IF{Umbrella Agreement}=1))," ^_^ ")
Hope that helps
NB (This is just formulas from memory - So may not be completely correct, but hopefully it will at least show you how to structure a formula like this.
