Help with invalid nested IF formula
1862 2
valushk
Screenshot 2020-01-10 at 17.18.44
I have two date fields and would like to pull out the months and years in separate fields from one or the other.
I managed to get the single IF working but not the nested function. Here’s my formula:
IF({Date A}, DATETIME_FORMAT({Date A},’YYYY’), IF({Date B}, DATETIME_FORMAT({Date B},’YYYY’)))
which I based on:
IF([logical argument1], [value1], IF([logical argument2], [value2], [value3]))
Any help would be appreciated.
Kamille_Parks
16 - Uranus
16 - Uranus
The reason for that is the use of curly apostrophes (’) instead of straight ones (')
I copied your formula exactly and it works for me. Is it possible that the {Date A} field in row 2 isn’t truly blank? Perhaps there’s an empty space in it?
Kamille_Parks
16 - Uranus
16 - Uranus
