How do I run block release in a monorepo? (Using npm workspaces)
2007 3
Eugene_Kim
I’m running issues when running block release to deploy my Airtable app.
I’m using npm workspaces as I develop my Custom Airtable App since I’m using a monorepo to make code management and sharing convenient.
Here’s the basic folder structure for my project:
  • project_root/
    • packages/ - houses workspaces
      • common/
        • contains code shared by airtable_app and server workspaces
        • package name: @shoptable/common
      • airtable_app/ - contains the airtable block app
      • server/ - another workspace
Here are the steps I take before running block release:
  1. npm i from project_root
  2. cd packages/airtable_app
  3. block release
I run into the following error:
building
copying package.json file
copying package-lock.json file
❌ Error: package-lock.json does not exist!
Failed to build the block code!
There’s only a package-lock.json generated at the project_root level. How can I get around this issue with my development environment?
Current Workaround
The only way I’ve found that works is to run npm pack on my @shoptable/common package and reference it in airtable_app/package.json's dependencies as such:
  "@shoptable/common": "file:../common/shoptable-common-1.0.0.tgz",
This isn’t ideal given that during development I’d like to simply refer to the workspace via the version number so as to make sure that I have the latest changes I’m working on.
Is there a better way to run block release given my monorepo setup?
Other things I’ve tried that didn’t work
In airtable_app/package.json I’ve tried declaring @shoptable/common as a local dependency like so:
  "@shoptable/common": "file:../common",
And then running npm i from within the airtable_app/ dir. This gets me a little further but I get the following failure after running :
building
installing node modules
[npm]
[npm] added 164 packages, and audited 166 packages in 2s
[npm]
[npm] 6 packages are looking for funding
[npm]   run `npm fund` for details
[npm]
[npm] found 0 vulnerabilities
transpiling and building frontend bundle
Bundle Error: Cannot find module '@shoptable/common' from '/private/var/folders/1t/rfq1yymx391fmcn0lj_9trm80000gn/T/airtableBlocks/build/1622060082006/transpiled/user/src'
❌ Error: Cannot find module '@shoptable/common' from '/private/var/folders/1t/rfq1yymx391fmcn0lj_9trm80000gn/T/airtableBlocks/build/1622060082006/transpiled/user/src'
Taylor_Savage
7 - App Architect
7 - App Architect
Hey there! We’re currently working on a new version of the CLI that generally is much more flexible around the types of builds it supports - hoping to have a beta release for this as early as next week.
In the meantime though - try running block release --disable-isolated-build with the current CLI?
3 Replies 3
Taylor_Savage
7 - App Architect
7 - App Architect
Hi @Taylor_Savage , that worked! Many thanks. Could you provide additional details on what that flag does?
It’s great to hear that more flexibility is on the way :slightly_smiling_face: How can I stay in the loop with these changes? The @airtable/blocks-cli project doesn’t seem to be publicly accessible.
@Taylor_Savage does the --disable-isolated-build flag work for block submit as well?
