How to get record by manual sort?
1239 2
Arvin_Xu
I can get records sorted by some field like below
  const records = useRecords(table, {
    sorts: [{ direction: 'desc', field: actionField }],
but how can I get records sorted by manual order?
Kamille_Parks
16 - Uranus
16 - Uranus
What do you mean by manual order? You can adopt the sorting of a particular view by pulling records from there as opposed to a table. Otherwise its going to be records.sort((a,b) => {insert your sorting logic here})
Kamille_Parks
16 - Uranus
16 - Uranus
That’s the solution.Thanks a lot!
