I have an AWS Lambda function written in python that is initiated by a Zapier trigger that I set up. As I pass some input parameters to the function in the Zapier trigger, I can access to the input parameters in my python code by using variables such as event[parameter1]
. It perfectly works.
I’m trying to access the same Lambda function in Airtable Scripting environment. In order to do it, I set up an API Gateway trigger for the Lambda function, but I can’t figure out how to pass input parameters in the vanilla JS environment. Below is the code that I have, which gives me “Internal Server Error” .
Your help would be definitely appreciated!
const awsUrl = "https://random-id.execute-api.us-west-2.amazonaws.com/default/lambda-function";
let event = {
"queryStringParameters": {
"folder_id": consFolderId,
"email": email
let response = await fetch(awsUrl, {
method: "POST",
body: JSON.stringify(event),
headers: {
"Content-Type": "application/json",
console.log(await response.json());
