Making use of same BASE FILTER with AND / OR (example)
Topic Labels: Views
1115 5
Sion_Cohen
I want to avoid replicate the same base filter 10X times on the same view
I could not find a combination for that.
Why is it limited ?
Ah I get it now.
you can do that by inserting a Condition Group inside a Condition Group.
Screen Shot 2022-08-22 at 3.59.16 PM
5 Replies 5
Hi @Sion_Cohen ,
Your question is a bit vague. You are already grouping those conditions in the first screenshot, what seems to be the issue?
The rounded condition (base condition) is common for both First group and Second group.
So instead of replicate it over each group like this:
(base condition and first condition) or (base condition and second condition)
I want to have:
base condition and (first condition or second condition)
Ah I get it now.
Got it thanks !
So generally speaking there is not limited to the or / and condition we can compose out of this form of grouping ?
Currently the limits are much less, but I haven’t tried adding more condition groups so not sure how much you can add.
