Need help with formula
2347 4
Patricio_Suarez
I want to be able to filter records and have the record numbers all concatenated into a single, comma-delimited, field. Possible?. I have tried ARRAYJOIN and CONCATENATE. Want to be able to copy all the filtered record numbers as a comma delimited text to be able to paste onto another program.
4 Replies 4
Hi @Patricio_Suarez - you can only concatenate fields within a record, not the same field across records. However, there is a way to do this.
Create a new table with a single record:
55
Here I’ve used a dot/period as the ID, but it could be anything.
In your original table, link all records to the new table dot record:
Back in the link table, you can see all of the records IDs in a single field:
You can transform these into a comma-separated list using the formula:
ARRAYJOIN({Table 3})
JB
Patricio_Suarez
Thank you so much for your help. Just tried your method and it works but I cannot only get filtered results to be passed onto the second table.
Want to be able to filter records:
and have only the record numbers from the filtered records go to the other table
I am limiting the records to be selected to a single view and I am filtering the content of that view.
Am I doing something wrong?
Incredibly grateful for your help.
You’re not doing anything wrong. Unfortunately rollup fields don’t recognize filters. They operate on all records in a table, filtered or not. That said, you can still get what you want.
Add a formula field named {Sold Records} to your main table, using the following formula (changing the names to match your fields as needed):
IF(Sold, {Record No.})
32%20PM
In the link table, add a rollup field:
The ARRAYCOMPACT(values) aggregation function will strip out the blank records, leaving only those with record numbers present.
49%20PM
Patricio_Suarez
Thank you so much. This worked. Very obscure way to do something that, seems to me, should be something easy to do.
I guess I have to use IF(SEARCH PARAMETER, {Record No.}) to get record numbers out of Airtable. I am also experimenting with copying the numbers directly from the Records No. column and reformatting them somehow to display as comma delimited text. They export with a return carriage between numbers.
