Post to Airtable not working, but GET is OK
Topic Labels: API
13331 16
Tiago_Formosinh
So this is what I am using to get my data from airtable
import axios from "axios"
formSubmitHandler = e => {
    axios
      .get(
        "https://api.airtable.com/v0/" + app_id + "/" + view,
        { headers: { Authorization: "Bearer " + app_key } },
      .then(resp => console.log(resp))
      .catch(error => console.log(error))
    e.preventDefault()
This works very well, however when I try to post something into the same table and now using this:
    const { name, email } = this.state
    const data = {
      "records": [
          "fields": {
            "Name": name,
            "Email": email,
    console.log(data)
    axios
      .post(
        data
    e.preventDefault()
It doesn’t work and I always get ERROR 401, and that shouldn’t be the case as I already managed to get the information out of my airtable.
Any ideas why this is happening?
Thank you,
Tiago
Thank you! I think the order was the thing that was wrong!
const data = {
      "records": [
          "fields": {
            "Name": name,
            "Email": email,
    let url = "https://api.airtable.com/v0/" + app_id + "/" + view
    let axiosConfig = { headers: { Authorization: "Bearer " + app_key , 'Content-Type': 'application/json' } }
    axios
      .post(
        url,
        data,
        axiosConfig
Like this works!
Thank you so much for the help!
Really appreciate!
16 Replies 16
Hi @Tiago_Formosinho_San - not sure if Axios is taking care of this for you, but looking at the AT API, I think you need to set the Content-Type header in a POST request (not required in a GET).
curl -v -X POST https://api.airtable.com/v0/APP_ID/Events \
  -H "Authorization: Bearer API_KEY" \
  -H "Content-Type: application/json" \
  --data '{
  "records": [
      "fields": {
        "Name": "Event 1",
        "Date": "2019-09-16"
      "fields": {
        "Name": "Event 2",
        "Date": "2019-10-01"
JB
Tiago_Formosinh
Hi @JonathanBowen, thank you for the super prompt repy!
well, get also needs it
curl https://api.airtable.com/v0//MailingList/
  -H "Authorization: Bearer YOUR_API_KEY"
EXAMPLE RESPONSE
    "id": "recEx8a5ewvtGGF3u",
    "fields": {
        "Email": "tiago@tiago.test",
        "Name": "Tiago"
    "createdTime": "2019-09-26T03:47:45.000Z"
and if I take out from my axios, it doesn’t work so I need to use it for the get.
 axios
      .get(
        {data}
What I was trying to say was both GET and POST need this:
But it looks like POST also needs this:
Have you tried a POST with “Content-Type: application/json”?
Tiago_Formosinh
Yes, I have tried that as well…
axios
      .post(
        url,
          headers: {
            "Authorization": "Bearer " + app_key,
            "Content-Type": "application/json"
        data
But it does’t work :frowning:
Any other recommendation so that I can try?
Super thank you for the help.
@Tiago_Formosinho_San,
The error you mentioned (401) suggests your troubles are security related and that has me thinking Content-Type is probably not the issue.
Describe for me what the value of view looks like? Is it URL-encoded?
Tiago_Formosinh
Thank @Bill.French!
const view = "MailingList"
const app_id = "MYAPPID"
const app_key = "MYAPPKEY"
const url = "https://api.airtable.com/v0/" + app_id + "/" + view;
The url would then be https://api.airtable.com/v0/MYAPPID/MailingList
Does it make sense?
I think that should be fine as it is working well for the get
Hi @Tiago_Formosinho_San - this worked for me:
<script type="text/javascript">
  const data = {
        "records": [
            "fields": {
              "Name": "Event 7",
              "Date": "2019-10-02"
  let axiosConfig = {
    headers: {
        'Authorization': 'Bearer YOUR_API_KEY_HERE',
axios.post('https://api.airtable.com/v0/YOUR_APP_ID_HERE/YOUR_TABLE_NAME_HERE', data, axiosConfig)
    .then(function (response) {
      // handle success
      console.log(response);
    .catch(function (error) {
      // handle error
      console.log(error);
    .finally(function () {
      // always executed
</script>
Can you work this into your code?
JB
(forget the “finally” function - not mandatory, I think. Was just copying some Axios boilerplate)
Looking at your code above you’ve got:
axios.post(url, config/headers, data)
I think you need:
axios.post(url, data, config/headers)
