Seeking: Web-based front end for Airtable base
2156 1
Harry_Brignull
Hi All,
I’m interested in getting someone to put together a web-based front end for an airtable base, one record per page. I’m currently using the Blocks “Page Designer” beta feature but it’s a bit inflexible for my needs.
This would be a paid freelance project, the code would likely be open sourced. Message me if you’re interested to find out more, then you can give me a quote.
Harry
Andrew_Schmitt
Check out Airpress for Wordpress. We don’t use/havent tested the functionality, but it has a way of mapping airtable records to Wordpress posts.
