Show modal dialog from SDK blocks
696 0
Dev_Flowpay
Is it possible to create a modal dialog that shows over whole screen from SDK blocks?
I can creade Dialog from SDK blocks but it shows only over my App on right side. I would like to create confirmation dialog that shows over whole screen, like delete record confirmation.
Is it possible with SDK blocks?
0 Replies 0
