For those of you needing to perform a Standard Deviation calc (STDEV() in Excel), here’s a template you can use for performing this calculation with values across a single row (record):
Where n = the number of fields SUM’d, ie, the number of POWER() statements.
You do have to manually enter each field that holds a value which you want factored in to the StDev calculation, and you have to have a field that calculates the averages of those values, so this will not work well for a dynamic data set (new values are constantly being added to the list of values needing to be included in the calculation).
I use it quite frequently in calibration specs, however, so I figured I’d post it here as a quick and easy reference for other people who were used to using the STDEV() function in Excel, but are not sure how to translate that into Airtable for simple data sets.
You just need an instance of this line for each value you need to include in the calculation:
POWER({Value 3 Field} - {Avg of Values Field}, 2)
Ensure that each POWER() statement has a comma after it EXCEPT the last one in the list.
Ensure that you replace n with the number of POWER() statements you included.
Hey Jeremy - thanks for this. Stats is not my strong suit, so I hope I don’t fumble to blindly here.
I have a series of scores from judges that I’d like to Z-score. Each project is scored by 3 judges, and each judge has scored 10 projects across 7 criteria on a 1-5 scale. Each project’s criteria & total score from each judge is on one row in the Scoring table.
So according to this, I should add a Function property on the Scoring sheet and add the Power equation. But just to be clear:
{Value 3 Field} in this case would be changed for {indiv. judge’s score total for this project} and
{Avg of Values Field} would be replaced by {average indiv. judge’s score totals, across all projects they scored}?
Hope I explained that correctly; please feel free to DM me with clarifying questions.
Hey @Tom_Quigley — so sorry I am just now seeing this! Since it has been some time now, have you found a workable solution? Or are you still trying to implement your Z-Score formula?
(for future reference, using @ tags can be a good way to get someone’s attention and ensure your response doesn’t get buried under all the rest)
I just received the first tranche of scores from judges, so I am going to start working on this in Airtable this week. I paused work on it a few weeks back as it wasn’t the most important thing to get done.
Michael, that’s really interesting about the StDev in the rollup field. Also interesting, it’s not supported in the actual Rollup property (though that seems to rely on the Function text box, so perhaps not surprising).
I had given up on trying to calculate StDev within Airtable, was going to just do it in Excel and then paste it into cells (since the judges scores won’t be changing after I receive them, the StDev doesn’t need to by dynamically calculated) - but with this rollup method I can cut out the middle-app and just paste direct from the rollup.
Jeremy - I’ll be testing that this week and report back if the Z-scores come out all wonky!
For some stats, I use an integration with google sheets where I then calculate and then feedback to AT using Zapier. This middle man technique in not very elegant but it works. It would be much better if AT just had these roll up functions (which they do have in the summary bar but don’t make available as rollups)
Update: the rollup at the top of the field didn’t calculate to enough decimal places, so I have been pasting my scores out to Excel, calculating STDEV there, and then pasting that back in. That’s been enough for me to calculate z-score pretty easily. Thanks all!
