Automation passes test but doesn't work IRL
Topic Labels: Automations
685 2
Raintiger1971
Hi there,
I have this automation I have built and it looks right to me and passes the test. The test data populates in the destination table. But when I manually enter data into the source table nothing happens.
Here is the automation:
 This is the destination table. The Article Number "F25NSECVR" was populated when I ran the test.
This is the source table. I manually entered "F25TEST" and nothing happened.
18 - Pluto
18 - Pluto
When the record is created, all of the fields are blank, so the automation run does not pass the test. You will need to use a different trigger or create your record using a form. One possible trigger is “when record meets conditions” and put the test for the text in the condition for the trigger.
18 - Pluto
18 - Pluto
Raintiger1971
Thank you so much! It took me a minute to figure out what you were trying to explain but now I get it. Posting the setup here in case it's helpful for anyone else.
