May 19, 2022 02:35 AM
I use an easy airtable script for the autonumber.
The problem is that it works for one table but not for a second or third table. Do you have an idea ? Is there an error? I keep checking but fields and everything seems correct to me.
Thank you for your answer
Mélissa
Solved! Go to Solution.
May 19, 2022 04:01 AM
Looks like you have a typo in the table name when you set the input variable. Should there be a space after the emoji?
May 19, 2022 06:39 AM
You’re right @kuovonne ! there was a space after the emoji.
Thank you so much :star_struck:
Have a nice day
Mélissa
