Ending an automation
Topic Labels: Automations
8201 18
jackline
I have an automation that triggers every day at a specific time.
I want to end the automation after a number of days.
How can I do that?
Thanks,
Jacqueline
18 Replies 18
i think i need it to start sending the emails. so when a record is created start sending emails.
but not sure since i added these two conditions at different times.
Actually the start date condition becomes redundant after day 1.
as long as the end date is set when the record is created, it should start sending them straight away.
Definitely raise this as a feature request with Airtable in product ideas. Time limited Automations would definitely have their uses. It’s worth noting that (at least if I recall correctly) an automation that triggers failed conditional logic will still consume an automation credit.
Further to a time/turn based automation configuration setting, I think that perhaps it would be cool if we could disabled enable automations via an automation script. 😁
yes, good idea.
Just as an aside, if I was trying to do this myself, I would use google apps script for more control over things.
Hi Steve, the end date is not equal to when the record is created. The start date is equal to when the record is created. End date happens after a number of days from the start date. I think you are right though that as long as the end date is after today it will send out the email.
I do not have coding skills to use google apps script.😅
Hey Steve, I received an e-mail that the automation failed 1 time. Could it be because the entry in the database came from a user with a different timezone than mine? Could it be because the automation works only in timezones in which they are created? Because when I checked what could have gone wrong - every step of the automation was successful - see screenshot.
Agreed - it is strange that there is no end date for automations.
Steve_Haysom
8 - Airtable Astronomer
Yes, strange that every step seems to have completed. I don't think being in different time zones makes a difference, the end date is either in the future or it's not.
I think the problem was that i am on the free plan and cannot send email through airtable. I changed it now to gmail. Should work with gmail.
