Help with FilterbyFormula
  • February 21, 2023
  • 81 views
Hi there,
I have this script I am working on to update all records in a table based on their currency. Except for records that are in stage 4. I am using this statement to filter through the records
filterByFormula: "AND(NOT({Currency} = ''), {Exchange} != '', NOT({Stage} = 'Stage 4'))"
The problem is that it ignores this parameter and rus it for all the records. I will be grateful for any help on how I can successfully filter out stage four records. Here is the full script.
const dealsTable = base.getTable('deals - test copy'); const currencyTable = base.getTable('test-currency exchange DB'); const deals = await dealsTable.selectRecordsAsync({ filterByFormula: "AND(NOT({Currency} = ''), {Exchange} != '', NOT({Stage} = 'Stage 4'))" }); console.log(deals); const updates = deals.records.map(async (deal) => { const currencyType = deal.getCellValueAsString('Currency'); const currencyField = currencyType.toLowerCase(); const currencyValue = deal.getCellValue('Exchange'); if (currencyField !== '' && currencyValue !== '') { const queryResult = await currencyTable.selectRecordsAsync({ sorts: [{field: 'Timestamp', direction: 'desc'}], filterByFormula: `{test-currency exchange DB} = "${currencyField.toUpperCase()}"`, maxRecords: 1 }); const currencyRate = queryResult.records[0].getCellValue(currencyField.toUpperCase()); return { id: deal.id, fields: { 'Exchange Rate': currencyRate } }; } }); await Promise.all(updates).then((updateResults) => { return dealsTable.updateRecordsAsync(updateResults.filter((result) => result !== undefined)); });
Forum|alt.badge.img+31
I think you need to encode the formula before use.  Here's your formula encoded using Airtable's API Encoder tool:
AND(NOT(%7BCurrency%7D+%3D+'')%2C+%7BExchange%7D+!%3D+''%2C+NOT(%7BStage%7D+%3D+'Stage+4'))
Relevant bit of the docs:
