Problems Inserting Hyperlinks in Automation Emails
  • June 23, 2022
  • 195 views
Hello, I’m trying to add a link to my automation, but nothing appears when I add the field even when using parenthesis. Could the fact that the url field/column is a formula link be the reason why the link does not appear in the automation?
Left is the column/url i’d like to pull in & the right window is the automation I am trying to set up. tyia!
JonathanBowen
Hi @Linna_Sim - what do you see when you generate a preview of the email? The fact the URL comes from a formula field doesn’t matter. Just checking - have you selected a record in the earlier part of the automation so that this part has data to work with?
  • June 23, 2022
Hi @JonathanBowen
Below is a screenshot of the record I tested. Except for the link field, all other fields do appear to function properly.
  • June 23, 2022
Hi @JonathanBowen
Did you retest your trigger first? If so, I would then remove those parentheses.
  • June 23, 2022
Or format the link as a markdown link.
Your submission link [here](formula-result-here)
Taha-Jiruwala
Forum|alt.badge.img+9
I have written an detailed article on how to add dynamic links to email automation. Check it out.
