Simple Automation Won't Turn on
Topic Labels: Automations
795 1
AirtableAdamant
I have a simple automation.  The test works fine but it clicking the "on" button doesn't work.
I've tried making new automations. They too have the same problem.
Any advice?
Thanks
Is your trigger set properly? Can you share some more screenshots so we can see what you set up?
