Wrong values between table and mailling automation
  • April 15, 2022
  • 18 views
Hi, sorry for my english that’s because I’m french. And also beginner on airtable.
I want to put the same values (rounddown) that is in my field to a mail automation; but in the mail the values is not round. Why? how to fix it?
thank you for your help.
  • April 15, 2022
Welcome to the community, @vivien!
Did you change your formula after setting up the automation?
If so, you will need to re-test your automation’s trigger step, in order for you to see the current fields & current field values in your automation action steps.
(This is just for the purposes of seeing current values while you are setting up your automation. But even if you don’t re-test the trigger, the automation will still pull in current values when it actually runs.)
