Accessibility Features or Extensions for Impaired Vision?
Topic Labels: Base design
292 1
Iballss
Was wondering if anyone has any suggestions for improved visuals / accessibility settings on Airtable? The latest update made it reeeeaaallly hard for me to see things like icons & symbols. Was wondering if someone had suggestions for extensions or settings that might add high contrast / easier to read text & symbols?
Arthur_Chedozea
Adding on this one, since the new updates it is almost impossible for me to see the difference between red and green. An accessibility feature would be greatly appreciated!
