Base Schema
  • November 28, 2023
  • 147 views
stevendasilva
Forum|alt.badge.img+9
Hello there,
Does anyone know how to export from base schema?
I want a snapshot image thats clear to show elsewhere.
  • November 29, 2023
I think that On2Air Backups is working on this for a future update — you may want to ask them about it.
stevendasilva
  • November 29, 2023
Thanks Scott! @ScottWorld
xcatena
  • September 5, 2025
I’ve built something that takes snapshots of your schema and also lets you export the schema in Markdown or JSON if you ever want to keep records or feed it to an AI chatbot/LLM to codevelop with:
AirDiff: https://airdiff.modernstack.io/product ​@stevendasilva
Forum|alt.badge.img+28
Hey ​@stevendasilva,
You might also want to check out n8n. You will absolutely not not get the nice visuals shown on the Base Schema extension, however you can still get the corresponding json with their Get base schema node.
YouTube Channel
Martin_Malinda
Forum|alt.badge.img+12
  • September 6, 2025
In any scripting block you should be able to do
output.text(JSON.stringify(base.tables))
