Using Condition function (filtering data)
Topic Labels: Data Workflow Design
479 0
Jendell_Duffner
I have a zip code field and only want 6 different zip codes from over 20 different ones I have in my data source.
I have successfully pulled those with the condition field use 'or'  but I also only want the ones that have an active customer  check marked.  when I place this as the 'or' field it then pulls all the other zip codes I do not want.  I am unable to place an 'and' condition successfully
I have resorted to grouping the active and inactive customers of each selected zip code but I want the inactive and active to be on separate reports (spreed sheet results) not one
What am I doing wrong with my condition codes?
In this view, show records
Where
Zip code
or
Zip code
or
Zip code
or
Zip code
or
Zip code
or
Zip code
or
Zip code
or
Zip code
0 Replies 0
