Script - Timing out after 30 seconds. Help to make more efficient
Topic Labels: Scripting
3211 6
rmc1977
I have written the script below to select records from one table in my base and insert them as new records in a second table.  The script is working, however it times out after running for 30 seconds.
The process is selecting and creating about 200 records.   Is there a more efficient way of writing this script so that it happens faster and doesn't hit the 30 second limit?   I've read that maybe i need to create an array so that multiple records are inserted at once, but I am brand new to scripting and not sure how to achieve this.
Any updates / changes / suggestions would be most welcome!
Thanks
//Script Purpose:
//1. Select fields "Client" and "Client Family" from all records in the table "Client Master"
//2. Using these values, create new records in the table "Bank Recs"
//Define source table
let table = base.getTable("Client Master");
//define fields to retrieve
const fldClient = table.getField("Client")
const fldClientFamily = table.getField("Client Family")
//query for all records in the Client Master Table
//Select specific Fields from that table, sort by Client Family then by Client
const queryResult = await table.selectRecordsAsync({fields: [fldClient,fldClientFamily],
 sorts: [
       // sort by "Client Family" in ascending order
       {field: fldClientFamily},
       // then by "Client" in ascending  order.
       {field: fldClient},
//View Query Result
console.log({queryResult})
//Define target table for creating new records
let targetTable = base.getTable("Bank Recs");
//Loop through all records in the found records
for (let record of queryResult.records) {
await targetTable.createRecordsAsync([
        fields: {
            "Client": record.getCellValueAsString("Client"),"Client Family": record.getCellValueAsString("Client Family")
Sho
11 - Venus
11 - Venus
I used ChatGPT 3.5 to get it fixed.
// Script Purpose:
// 1. Select fields "Client" and "Client Family" from all records in the table "Client Master"
// 2. Using these values, create new records in the table "Bank Recs"
// Define source table
// Define fields to retrieve
const fldClient = table.getField("Client");
const fldClientFamily = table.getField("Client Family");
// Query for all records in the Client Master Table
// Select specific Fields from that table, sort by Client Family then by Client
  fields: [fldClient, fldClientFamily],
  sorts: [
    // Sort by "Client Family" in ascending order
    { field: fldClientFamily },
    // Then by "Client" in ascending  order.
    { field: fldClient },
// Create an array to store records to be created
const recordsToCreate = [];
// Loop through all records and add them to the array
  recordsToCreate.push({
    fields: {
      "Client Family": record.getCellValueAsString("Client Family"),
// Define target table for creating new records
// Define batch size for creating records
const batchSize = 50;
// Function to create records in batches
async function createRecordsInBatches(records) {
  for (let i = 0; i < records.length; i += batchSize) {
    const batchRecords = records.slice(i, i + batchSize);
    await targetTable.createRecordsAsync(batchRecords);
// Call the function to create records in batches
await createRecordsInBatches(recordsToCreate);
Does it work?
6 Replies 6
corb1
Not sure of your requirements but is there a need to use a script here? Could you just use the native automation methods - Find Records in table1, then in a repeating group, use the create record action and use the data from prior Find Records step.
rmc1977
I tried this, but the results of the find records step is limited to 100 resulting records.  My found set has about 200 - 220, so I think I need to use a script.
.... unless there is another way around the limit?
Sho
11 - Venus
11 - Venus
createRecordsAsync function can create 50 records at a time.
It would be a change to pass the records to be created once to an array and process 50 records at a time.
rmc1977
How do I pass the records to an array?
Sho
11 - Venus
11 - Venus
// Script Purpose:
  sorts: [
    fields: {
Does it work?
rmc1977
YES!!
Thank you.  (and it runs really quickly).
Really appreciate the help
