Formula for $ does not add up correctly
  • November 23, 2020
  • 53 views
We have been running into a snag with the simple formula of 3 columns adding together and getting off by .01. This normally is not a big deal, but in a contract this can be a very big deal. I have attached the pictures of what I’m talking about and the formula I use.
  • November 23, 2020
Welcome to the community, @Tyler_Surrency!
What that means is that one or more of your formula fields are rounding their numbers for display purposes, but the actual numbers are much longer.
Go in & customize your formula fields, click on the “Formatting” tab, and choose a different precision. Then, you will be able to see where the problem lies.
Also, you can just Round your formulas by adding the ROUND() function into your formulas.
  • November 23, 2020
Can you show me in this formula how rounding would work to solve my issue?
Tyler
  • November 23, 2020
Tyler
You can just wrap the entire formula with the Round function. Something like this:
ROUND(
{Field 1} + {Field 2} + {Field 3} + {Field 4}
,2)
But you may be better served by going back and rounding the other formulas, too, to yield more accuracy.
  • November 23, 2020
ROUND(
,2)
I went back to where it generates the monthly payment automatically. Iput in the formula you wrote me and it worked.
Thank you for your help.
Tyler
  • November 24, 2020
I believe you are dancing around this floating point math bug.
