Having a wee bit of brain trouble today with a formula
115 3
RonniEloff_VKDe
7 - App Architect
7 - App Architect
I have a formula that worked but I decided to go and mess with it.
I have a Date field that is the date of the task action
I have a Days to next action field to add to Date field to define next time to attempt the task (normally a callback)
I have a Next Task Date formula field that shows the Date for the next task based on Date + Number of Days  - and it was nicely working
The formula in the Next Task Date field looked like this - DATEADD({Date }, {Days to next action}, 'days')
However I don't want the formula to put anything in the Next Task Date if the Numbers of days is blank
Here is my current formula
If ({Days to next action}=BLANK(), DATEADD({Date }, {Days to next action}, 'days'))
It's failing and I can't figure out why.
Thanks in advance for helping
15 - Saturn
15 - Saturn
Try:
  DATEADD({Date}, {Days to next action}, 'days')
3 Replies 3
15 - Saturn
15 - Saturn
Try:
Thanks.  Can I ask why Blank() wouldn't work here.  It was a solution from another problem I found in the Community that almost mimicked my issue of what I was trying to accomplish
I'm not sure either I'm afraid heh, hopefully someone else can answer that
