Help with Formula
946 3
AdamHassig
Hello, wondering if someone could help me correct the formula in the photo.  I am hoping for this to happen:
If OLD JOB# is blank, display current 2 digit year (CREATED DATE) & "-" & 4000 + ID#.
If OLD JOB# is NOT blank, display OLD JOB#
For example, looking at the last 2 rows at the bottom, 42 is correct, but 43 should display "24-4183"
18 - Pluto
18 - Pluto
Try this:
  {Old Job #},
  {Old Job #},
  RIGHT(
    YEAR({Created Date}) & "",
    2
  ) & "-" & (4000 + {ID #})
3 Replies 3
18 - Pluto
18 - Pluto
Try this:
  {Old Job #},
  {Old Job #},
  RIGHT(
    2
AdamHassig
I was able to make this work.  Thank you for your help!
An explanation of why the formula was failing:
The first argument of the "RIGHT" text operator requires a string. However, YEAR({Created Date}) returns a number. To fix this, you need to convert the result of YEAR({Created Date}) to a string. You can do this using the & operator and adding "".
For example:
RIGHT(YEAR({Created Date}) & + '', 2)
                           ^^^^^^ this part does the trick
I hope this helps! If you need assistance with implementation or anything elsefeel free to schedule a 15min call with me
