Jan 10, 2020 09:36 AM
I have two date fields and would like to pull out the months and years in separate fields from one or the other.
I managed to get the single IF working but not the nested function. Here’s my formula:
IF({Date A}, DATETIME_FORMAT({Date A},’YYYY’), IF({Date B}, DATETIME_FORMAT({Date B},’YYYY’)))
which I based on:
IF([logical argument1], [value1], IF([logical argument2], [value2], [value3]))
Any help would be appreciated.
Solved! Go to Solution.
Jan 10, 2020 10:50 AM
The reason for that is the use of curly apostrophes (’) instead of straight ones ('
Jan 10, 2020 10:18 AM
I copied your formula exactly and it works for me. Is it possible that the {Date A}
field in row 2 isn’t truly blank? Perhaps there’s an empty space in it?
