Need Help Calculating Par
98 1
Noochy12
Good evening! I'm creating a scorecard for golfers, everything is going well except, I can't figure out how to calculate their +/- score. I have the total score but I don't know how to add the static numbers of par to each hole so I can formulate the calculation to get the +/-. Score Question.jpg
May I know what problems you had with using SUM() for this?
With reference to your screenshot, could you indicate which fields you want summed together?
