Output Markdown from field data using formula
  • April 9, 2024
  • 95 views
I've been using a very hacky method of generating a Markdown table using a formula in my base. The below example uses Markdown in quotes for the table structure, and then pulls from field data to populate the table.
Example:
" # DIVINATION " & "\n" & " | Divination | Result | Description | " & "\n" & " |-|-|-| " & "\n" & " | " & " Soothsayer's Deck " & " | " & {Soothsayer's Deck} & " | " & {Soothsayer's Deck Description} & " | " & "\n" & " | " & " Constellation " & " | " & {Constellation} & " | " & {Constellation Description} & " | " & "\n" & " | " & " Position " & " | " & {Position} & " | " & {Position Description} & " | " & "\n" & " | " & " Moon Phase " & " | " & {Moon Phase} & " | "
I then use an automation to populate a "Calculation Output" field using an example from @kuovonne in this thread.
The result outputs:
| Divination | Result | Description | |-|-|-| | Soothsayer's Deck | The Yoke | Burdens shared or intensified. Collaboration or hardship. | | Constellation | The Key | (choice / power) | | Position | Ethereal | (delicate / insubstantial) | | Moon Phase | Waxing Gibbous |
I can then paste this into Obsidian to create a table.
I have two issues currently:
1. It results in a Markdown output with a line break on each line. This is because I need to use "\n" or the resulting Markdown will output like this:
This is no use for me as when I paste it into Obsdian, it doesn't generate the table without me individually pressing enter to create a new line. This is unwieldy because...
2. This is just a small example - the actual base has over 100 fields and 36 rows so the resulting code is unwieldy. I separate the calculations by title (General, Fate etc.)
Is there a simpler method to achieve this output?
Here's an example base with a portion of the records if you'd like to dig around: Base
Any help appreciated. Thank you.
