Save the date! Join us on October 16 for our Product Ops launch event. Register here.
Mar 06, 2024 11:37 AM
I'm setting up an interface that will serve as a dashboard to show my time overall client financial info. I used rollups so all the data would be in one table which will allow people viewing the dashboard to only use on filter to filter by client.
The only problem I'm running in to is I would like to have the interface say "The client was last invoiced on RECENT DATE" I tried using a max() formula in a rollup column. The problem I'm having is that it's returning 2/29 as the most recent date when I have dates from this week, first week of March. How can I make sure it's actually showing the most recent date?
Mar 06, 2024 06:14 PM
Interesting! Could you share some screenshots of your tables and data? I don't think I've ever seen MAX not return the latest date!
Mar 07, 2024 10:19 AM
I can't because of the client info but I figured out what the glitch is. I played around with the dates and the MAX() is calculating a day behind. So if my most recent invoice date was March 1st then it's showing Feb 29th. If it was March 7th then it shows March 6th. I have no idea why that is.
Mar 07, 2024 05:10 PM
Ah, it's probably down to timezone weirdness. Could you try setting the timezone of your rollup field to the same timezone your date field is in?
