Format interface buttons in record detail
1827 2
Ella
7 - App Architect
7 - App Architect
Does anyone know how to format buttons in an interface record detail?
For example, I would like to move the buttons around and have all 3 be the same size and display at the same time instead of having the weird drop down menu. Also I would like to reorder the position of the buttons.
Thanks in advance for any suggestions!
18 - Pluto
18 - Pluto
You can try using the old style of record details page that lets you add button elements. I don’t remember the exact procedure for reverting to the old style, but if you poke around you should be able to find it.
Thank you @kuovonne , I will try that
