Grid View in Interface does not preserve ordering
  • February 15, 2023
  • 60 views
I've created a Grid View in my base, and created a specific order by dragging and dropping records (not using a Sort condition). When I share the view, the order is preserved. When I add the view to an interface, the order is NOT preserved.
What are my options? Is this a bug that will be fixed? Is there an easy way to create a priority field of some sort instead that will auto-change when I re-order the records based on changing priorities?
  • May 28, 2024
Facing the same issue here, there seems to be no way to save a default sort or group for an interface.
