Issue with Double Numbers in Dashboard
678 1
EmilyGG
I am using a summary of data connected to a linked record to populate the dashboard. The Youth Care Professional 3rd shift seems to be filtering as two numbers separated by a Comma. I am not sure why this is happening there and not with the others. The fields have the same conditional formatting for all the fields to the right of linked record. Only this one seems to be noting as 2 numbers.
Hmm, if it's computed and it's a formula that suggests it's a lookup field.  Is that record linked to two other records perhaps?
