Help with IF nest formula
3914 10
Emmanuel_Saint-
I am trying to return “Late” when one or several function fields have a date that’s before today AND an attachment field is empty. I have tried the following formula but it’s not working. What am I doing wrong?
AND(
IS_BEFORE(
{Due Date Sponsored Article},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date Sponsored Agenda},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date NL Banners},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date EMail Blast},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date Website Banners},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”))))))
10 Replies 10
Your formula is not well formatted:
	AND(
		OR(
			Date Check 1,
			Date Check 2,
			Date Check 2,
		{Assets}=""
	'Late',
	'Upcoming'
Change the “Date Checks” to a proper functions, I didn’t want to write all of them :grinning_face_with_smiling_eyes:
Thank you Elias, exactly what I needed!
I might have been too quick to respond actually. There is still something I am doing wrong. Here is the code I am trying:
AND(
OR(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
{Assets}=""
“Late”,
Could it be due to the fact that some of the date fields are empty? If that’s the case, is there a way around?
Your {Assets}="" is inside the OR() instead of the AND():
What error are you getting?
You are using two different types of quotation mark in that formula. I don’t think the curly ones around the word late are compatible with airtable formulae.
This is often an Apple problem because their keyboards default to using the curly quotation marks.
Thank you Elias
I am getting Error returned whenever one of the dates is blank (which happens most of the times). When all date fields have a date, it works fine.
I think is because of the IS_BEFORE, you can check that. Maybe you have to wrap all of them with IF({Date}, [formula]).
Emmanuel_Saint-
I am trying to use an IS_Before check date with AND, IF and OR. It’s working but only when all date fields have a date. If a field is blank, it returns ERROR.
Then I tried to wrap each IS_BEFORE check in an IF(). No more errors, but the formula doesn’t return anything at all.
Anyone seeing what I am doing wrong?
AND(
OR(
IF({Due Date Sponsored Article},
IS_BEFORE(
IF({Due Date Sponsored Agenda},
IS_BEFORE(
IF({Due Date NL Banners},
IS_BEFORE(
IF({Due Date EMail Blast},
IS_BEFORE(
IF({Due Date Website Banners},
IS_BEFORE(
{Due Date Website Banners},TODAY())))))),
{Assets}=""
“Late”,
Why you don’t reply to the original post?
You have nested the IFs:
Close them before starting the new one.
