The Community will be undergoing maintenance from Friday February 21 - Friday, February 29 and will be "read only" during this time. To learn more, check out our Announcements blog post.
Is there a way to sort chronologically?
Topic Labels: Extensions
19901 15
erlend_sh
I see that I can sort by 1 -> 9 or A -> Z, but is there a way to sort chronologically?
15 Replies 15
That’s not what I get when I sort by date at all.
When I sort by a “Date” field by 1 -> 9:
I get appropriate sorting by Year, Month, Day:
Aaron_Linsdau
Yes, you can sort by date. This was killing me, too. Set your date format to:
ISO (2019-01-22), that’ll make the sort work properly. Then you can autonumber if you need to enforce a sort by item added.
RommelParas
But it doesn’t work the same for pivot tables and charts
Katelynn_Straw1
I’m trying to sort by date as pictured below and it’s clearly not working. What am I doing wrong? The numbers don’t change whether I do 1-9 or 9-1…airtable
Hi Katelynn – sorry if we don’t make this clearer.
On grouped views, the Sort menu affects the order of records within a grouping, and not the order of the groupings themselves. You can change the order of the groupings from the Group menu (in this case, the grouped field is a linked record field, and in turn cannot be sorted by date).
I might recommend grouping first by the Due date field, and then by the Customer field. Or you can just as well sort by the Due date field and then by the Customer field.
Hope this helps a bit.
I removed the grouping, then sorted by in home dates and then re grouped by customer which gave me the result I was looking for.
Hopefully this continues to work as I add to the table!
Thanks for your assistance!
