Hi, I am currently developing the check in and check out for a laundry and I generated their dashboard so they can see the result of their operation per day.
As a context for the issue I have the following.
Each service order has an entry date and an exit date, as well as an amount that you were able to leave at the time you left your service or pay at the end.
The issue I have is that it is not possible for me to do the sum of the inputs with the total of the outputs (total ingresos).
The result that should be in this field when I see the information at grid level is added, but when I put the field that has this data, it only gives me the income part.
I have already tried to put conditions in the number so that it can bring me all the information but I can't figure out how to do it.
Any help is welcome. Thanks for your help
