Using / creating shared library for Script blocks / Automations
Topic Labels: Extensions
1184 1
John_McParland
Is there some way to create code that is shared between multiple scripting blocks? Either by external import from some source, or a native solution?
Example: I have a function addClientToSession(clientRecordId, sessionRecordId) that I want to use in multiple blocks. Right now, I have to copy and paste the function into each scripting block or automation step I want to use it in, and if I want to update it, I have to be sure I edit every instance. I’d much rather be able to do something like import addClientToSession from "shared-block-id".
If this is impossible, what solutions have other people in the community used to accomplish something similar?
cideck
Hi, indeed scripting in AirTable is awesome both via scripting block and automations, but I also need to be able to re-use my javascript code in various automations. Looking for some kind of import or include feature, but it does not seem to exist yet. Very interested if anyone has a solution, otherwise it will soon be a nightmare to maintain…
