- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
Aug 13, 2020 06:04 AM
Hi all,
Having a bit of issue with setting up an Automation. I was wondering if someone could help me?
When a new record enters “Tab B”, I want it to link to “Tab A” if the ‘Vehicle Registration’ matches.
“Tab A” will already have all Vehicle Registrations listed, so any new records entering “Tab B” will not be random or different.
At the moment I’m having to manually click on the Linked Fields column in order to add the record from 'Tab B" to “Tab A”.
I have a feeling this might be an easy to do in JS but I’m confusing myself at the moment.
Any help would be greatly appreciated!
Mitch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Aug 13, 2020 07:35 AM
Try looking at this answer to another thread:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oct 19, 2020 03:35 PM
Hello, @Kamille_Parks.
Can you help with that as well?
I have a main table called Upcoming Events and I have another table called Design Services.
If any field is updated into the main table, I should update the Design Services table.
I couldn’t make using your script.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oct 19, 2020 04:07 PM
You can’t pass the record ID from Upcoming Events
into PS - Design Services
because that record ID only exists in Upcoming Events
Are you using my script at all? Nothing in that screenshot indicates that you are, as you’re only pulling values from the trigger record.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oct 19, 2020 07:32 PM
Hi Kamile,
I am sorry…I am not familiar with scripting
Here is the screenshot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oct 19, 2020 07:46 PM
Your Line 1 of the script isn’t supposed to be part of the script itself. In the thread you were following I was describing how to do this with an Automation Script Action, not the Scripting App. You have given a screenshot of the Scripting App.
Correct the spelling of .selectRecordsAsync()
(that’s my mistake), move the code into a “Run a script” step of an Automation, and instead of including Line 1 set up an input variable within the Run a Script action (it will be the left side of the screen when editing the code) using that format.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oct 19, 2020 08:04 PM
Hi Kamille…
Thanks a lot for your advise.
I understood now.
To run a script action I need to upgrade my airtable account.
I will ask my manager to do so.
Thank you for your help
