Average percent formula help!
1269 2
Katherine_McDer
Hi! I need a formula to calculate the average of the previous 4 weeks %. Screenshot attached. Does anyone know what I would need to put in for that?
I’m assuming the July overall column needs to be a formula, right?
Screen Shot 2020-07-09 at 2.29.58 PM
The summary headers are to summarize rows (records), but you’re trying to summarize columns (fields).
You need to create a formula field using the AVERAGE function.
Paul_Warren
8 - Airtable Astronomer
Yes, use a formula looking something like this
Average({Week 1}, {Week 2},…)
