Can i purchase plus plan using account credit i have 20$ credits but how can i purchase please help
1328 1
pubg_guru_tourn
can i purchase plus plan using account credit i have 20$ credits but how can i purchase please help.
M_k
11 - Venus
11 - Venus
Hi @pubg_guru_tournament
I found a link, while searching online.
Here it is, I hope it helps (the information about applying a credit is near the bottom of the webpage):
Applying personal credits to a workspace
Airtable credits (received by, for example, referring others to Airtable or installing the Airtable mobile app) can be applied toward a workspace which is on a paid plan. Please note that you must ...
Mary Kay
