Creating a formula to filter for a date range as well as a check box
1585 3
Adam_Reker
I’m looking for help to write a formula that will help filter records that meet these requirements. I can’t seem to get it done using the filter function.
Where date is within the next week
or
Where date is within the last 3 days
and
Where check box is not marked
3 Replies 3
Per_Carlen
7 - App Architect
7 - App Architect
Hi and welcome to Airtable!
Do you mean literaly within the next week, like within week 39 now, or do you mean within the next 7 days?
Per_Carlen
7 - App Architect
7 - App Architect
Try this:
  OR(
    DATETIME_FORMAT(Date, 'W') = DATETIME_FORMAT( DATEADD(Today(), 1, 'weeks') , 'W'),
    And(
      IS_BEFORE(Date, Today()),
      IS_AFTER(Date, DATEADD(Today(), -4, 'days')),
      Checkbox = 1
"Meets criteria",
"Don't meet criteria"
Thank you so much - I actually figured out a way to force it to work by reordering the filters!
