Creating sums of certain values in a column
831 1
Rachel_Bedolla
05|689x221
Hello! I’m trying to create a way to see the total incoming/outgoing expenses of each month, as well as incoming-outgoing, and profitability percentages. Is there a way to make some way to see those individual sums, as well as totals for year (if for example I had a full year filled with values.
Thank you for your help!
Hi @Rachel_Bedolla and welcome to Airtable Community :smiling_face_with_three_hearts:
I see two options for you. Either create new views grouping your data by Field1 which will then show the sums or, if you’re on the Pro version, you could utilize the Pivot Table block.
